Use BGP Debugging Commands
Use global and peer debug commands to display specific debug messages for the global and peer Border Gateway Protocol (BGP) configuration, including the BGP neighbors.
You can use these commands to troubleshoot the BGP configuration.
  1. Enter BGP Router Configuration mode:
    enable
    configure terminal
    router bgp
  2. Show specific debug messages for the global BGP configuration:
    global-debug mask WORD<1-100>
  3. Display specific debug messages for the global BGP neighbors:
    neighbor-debug-all mask WORD<1-100>
  4. Display specific debug messages for BGP peers or peer groups:
    neighbor <nbr_ipaddr|peer-group-name> neighbor-debug-mask WORD<1-100>
  5. Display debug messages on the console:
    debug-screen <on|off>
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# router bgp
Display the global debug messages for error and packet:
Switch:1(router-bgp)#global-debug mask error,packet
End (disable) the display of global debug messages:
Switch:1(router-bgp)#global-debug mask none
Switch:1(router-bgp)#neighbor-debug-all mask packet,event
Switch:1(router-bgp)#neighbor 192.0.2.10 neighbor-debug-mask event,trace
Switch:1(router-bgp)#debug-screen on
The following table defines parameters for the global-debug mask and neighbor-debug-all mask commands.
Variable
Value
WORD<1-100>
Specifies one or more mask choices that you enter, separated by commas with no space between choices. For example: [<mask>,<mask>,<mask>...]. Options include: none, all, error, packet, event, trace, warning, state, init, filter, update.
The following table defines parameters for the neighbor command.
Variable
Value
Specifies the IP address or the group name of the peer.
WORD<1-100>
Job Aid
Use debug command values to control debug messages for global BGP message types, and for message types associated with a specified BGP peer or peer group. The following table identifies mask categories and messages.
Table 1. Mask categories and messages
Mask category
Message
none
None disables the display of all debug messages.
all
All configures the device to show all categories of debug messages.
error
Error configures the device to show error debug messages.
packet
Packet configures the device to show packet debug messages.
event
Event configures the device to show event debug messages.
warning
Warning configures the device to show warning debug messages.
init
Init configures the device to show initialization debug messages.
filter
Filter configures the device to show filter-related debug messages.
update
Update configures the device to show update-related debug messages.
